07-17-2022, 08:57 AM - 1 Like   #1
SMC Macro Takumar 50mm f4 M42
I am not sure if this is the right forum to ask this question - but I might as well try
I have an old SMC Takumar that was fitted to Asahi Pentax bellows -- and unbeknown's to me there is a small pin that has engaged in the bellows and now I cannot remove the lens from it.. I understand this is a problem and hindsight is a wonderful thing
if I have to "sacrifice" the bellows - fine and I just can't find any other option to unscrew this lens .. and its a lovely lens and I have had some great results with it on my Fuji X
Any advice or guidence would be greatly appreciated
Greetings from Ireland
Paul
07-17-2022, 10:13 AM   #2
Not a Number's Avatar
Which bellows is it? I'm not aware of any pins that would cause a problem on the M42 bellows. If you are using a non-Pentax M42 adapter on one of the K-mount bellows it could be a problem.
Either way you should be able to get at the rear of the lens through either by collapsing the bellows or with the Auto bellows detach the bellows from the front standard.
If it is a k-mount you should be able to release the spring clip on the adapter then remove the lens and adapter. After that you can depress the pin with a small screwdriver or something to remove the adapter.
If not, you can try fitting a thin feeler gauge between the lens and mount to depress the pin.
07-17-2022, 06:29 PM   #3
K2 to K50's Avatar
I recently discovered on my "Pentax Auto-Bellows K set" Bellows from the late 1970's that I can unscrew the camera mount from the body of the bellows. Haven't checked if the same applies to the lens mount at the other end, but if so, that may make it easier to work with?
07-18-2022, 04:36 AM   #4
Send a picture of the lens and bellows and someone will probably know how to fix the problem
07-19-2022, 04:30 AM   #5
The bellows is Asahi M42 see photo
I have the bellows closed but the lens wont unscrew.. its kinda loose but definitely something (small pin) preventing from unscrewing
Does anybody have a Takumar (SMC) 50mm macro lens that may show any pin... can possibly get a small feeler gauge in between the lens and the bellows but can't see what this might achieve
Thanks for any assistance or further advice
Paul
IPhone 12 mini  Photo
07-19-2022, 04:39 AM   #6
Tacumar SMC 50mm M42 pin..?
See attached image that shows the pin
Paul
07-19-2022, 05:18 AM   #7
Did you tried to unscrew with different positions of auto/man (A/M) switch on the lens?
07-19-2022, 09:47 AM   #8
Ok, the only thing the auto/man release pin could be hanging up on would be the mount screw holes. Even though the pin should be on a different radius from these holes.
A feeler gauge would depress the pin and cover over the hole allowing the pin to pass over the hole.
07-19-2022, 01:45 PM   #9
GUB
GUB's Avatar
Maybe there is a screw missing in the bellows mount leaving a hole. Looking at my asahi bellows the pin would line up with the inner edge of the hole. i would have thought it would have just ridden back out again though.
07-19-2022, 05:42 PM   #10
If the pin isn't depressed then the auto/manual switch will lock in the "auto" position. So in this case if the switch can be changed back and forth from auto to man then the problem must be elsewhere. Unless of course the switch is broken.
07-19-2022, 07:38 PM   #11
GUB
GUB's Avatar
With both my S-M-C Macros the pin stays recessed even when the lens is off. And only one out of 5 of my S-M-C / SMC 55s is stuck down.
Any one else with a SMC Macro 50 able to check?
Maybe it was a nuisance as in here and disabled.
07-19-2022, 07:46 PM   #12
GUB
GUB's Avatar
So I just took the mounting plate off my bellows and tested it on a SMC 55mm and it did jam just as described.
The advantage of taking the mount off was I could recess the pin manually from behind. Sorry but this describes your problem but doesn't solve it. I think a screw is missing in your bellows mount ring.
EDIT I think it was the screw hole at 7 0clock that caught the pin. Figuring the bellows is going to have to be destroyed but - Try inserting a fine screwdriver between the chrome bellows mount and it's black plate at this 7 0clock position and see if you can get any play. And slowly force your way around the mount and try and shear the other screws. The best case scenarion is you destroy your screws but can glue the mount back on. It is possible that it may not be the screw at 7 0clock missing - it is just that it is the last one the pin passes over.
07-19-2022, 07:58 PM   #13
On my Super-Multi-Coated Takumar 50mm f/4 macro the pin stays in when set to "man". If you switch it to "auto" the pin pops out and it locks in "auto" until you depress the pin. When set to "auto" the pin pops out when you release it after pressing it in (spring loaded).
07-19-2022, 08:12 PM   #14
GUB
GUB's Avatar
Then my two have either stuck with age or someone has glued them.
Edit even though the pin isvery fine I suspect it will extend too far for a feeler gauge to get under it but here is hoping.
And I wonder if my ones are stuck because someone has forced them and bent them a bit. (It may be the way to go)
EDIT again. If the screw slot happens to be in the exact radial from the centre position then it could trap the pin just like a missing screw.
07-19-2022, 08:32 PM   #15
GUB
GUB's Avatar
Post 2
https://www.pentaxforums.com/forums/8-film-slrs-compact-film-cameras/229285-...ty-issues.html
camera, lens, macro takumar 50mm, smc, smc macro takumar, takumar, takumar 50mm f4, vintage
More of my unscientific tests. Pentax-M SMC F1.7 50mm vs. Pentax-M SMC F4 Macro 50mm Michael Piziak Pentax SLR Lens Discussion 15 02-25-2022 04:02 PM
SMC Takumar 50mm F1.4 screw mount M42 vs XR Rikenon 1:1.7 50mm vs Smc pentax-A 1:2. 5 pgaikwad Pentax SLR Lens Discussion 11 11-29-2015 12:56 PM
M42 SMC Takumar 17mm F4 or save for DA 15mm Ltd F4 Douf Pentax SLR Lens Discussion 4 11-27-2012 06:24 PM
For Sale - Sold: Asahi macro Takumar 50mm f4 (1:1 macro) M42 (Worldwide) EricR Sold Items 2 04-11-2011 11:45 PM
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
All times are GMT -7. The time now is 06:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
