RE:
Close-Up Portraiture Originally posted by Tonytee Now I notice there are comments and recommendations offered on this subject however, they are quite old and there have been Quantum Leap advancements in technology since as far back as 13 years. I am aware there are many third party offerings out there however, I am focused on Pentax exclusively for high IQ. I am currently using a Pentax k-7 and will consider an upgrade if I have to.
The thread title leads me to a subset of the portrait genre where
the head is framed tight and there isn't much context or background around the subject. What tools are best suited for that kind of job? The simple answer may be: your Pentax K-7 camera and a Pentax
HD FA 77mm F1.8 Limited lens. The more nuanced answer may have many more ingredients besides a camera and lens.
Hint #1: If this is about
snapshots, about seizing a moment that may not happen again, then the best tools are always the ones you already have with you, at hand.
I would generally avoid
close framed snapshots if the lens has less than 50mm, because of distortions - the apparent size and shape of facial features (bigger nose than in reality).
85mm or
135mm lenses may be better than 50mm, but that is with the framing done on full-frame cameras. The Pentax K-7 is not full-frame, you have to multiply 1.5 times the focal length of your lens to get an
equivalent field-of-view, that is how tight it would look like, on full frame. A 90mm lens on K-7 would have the same field-of-view as a 135mm lens on the full-frame Pentax K-1.
Hint #2: if I had unlimited budget then I would use a full-frame camera for such portraits (a Pentax K-1) and I would buy a dedicated portrait lens, such as the HD Pentax-D FA* 85mm F1.4. Plus the HD FA 77mm F1.8 Limited. Plus the HD Pentax-D FA* 50mm F1.4 SDM AW. On a limited budget I would use a film-era Pentax ME Super and a "nifty-fifty" with 1.4 aperture. Or a Samyang 135mm f/2.
Hint #3 regarding large apertures: On a digital camera, with an APS-C size sensor (such as on Pentax K-7 or Pentax KP) I would still like wide apertures, f/2 more than f/2.8, knowing that the 1.5 crop factor is affecting depth-of-field (DOF) too, meaning that the Pentax K-7 is less suited for the job because it gives a deeper zone of sharpness, countering the effect of a large aperture. If you are looking for
shallow depth-of-field then a
full-frame camera is better suited than a crop-sensor camera. Then again, if all you want is f/8 for maximum DOF in a studio setting or a fleeting "catch-all" situation, then large aperture lenses don't matter at all and crop-sensor cameras are actually better than full-frame.
Hint #4 is addressing the
advancements in technology: Not so much at Pentax but at
other manufacturers. It's related to the autofocus (AF) system. You would want to use a feature that automatically keeps focus on the eyes of your subject, in a continuous and accurate manner, even with minute changes of position and distance between the camera and the subject. While good portraits are of course possible with manual focus lenses, it is so much easier if the camera takes care of the critical eye AF. A wrong setting makes the portrait unusable and the wider the aperture is, the harder it is to keep the eye in-focus. Pentax is not the best choice for that, nowadays. It takes considerable skill with the cameras we have (on PentaxForums).
Hint #5: during recent years advancements happened on the triggering and control of speedlights (flashes) and for the Pentax line of cameras I like the Godox system of radio triggers and remote, off-camera flashes. For close framed portraits that advancement means better (finer) control of the power level of several flashes at once. One flash used as a key light with a modifier, one used to fill up the shadow areas and another used as a hair-light or rim-light. Previously the investment may have been much larger but now it's accessible for everybody. The trigger unit sits on the camera and allows me to tweak the light on different parts of the image without needing to reach and touch any of the flash units which are positioned further away. Touching them would possibly affect the relative position between light and subject, breaking a fine-tuned effect. And it would take more time.
Hint #6: relates to "portraiture" as a form of art, where both the artist and the model have lots and lots of time to get one fine portrait.
As others have said before, "a good portrait
is not made in the camera but on either side of it". The interaction between the subject and the photographer has to be right. The skill level of the photographer has to encompass many things:
- knowledge of light and lighting (similar to how the famous painters asked their subjects to keep a position where light falls on the face in a certain way and the light has a certain type, quality, softness, color temperature - all of that was deliberately chosen)
- ability to catch a decisive moment - a very fleeting moment in time - or at least take so many pictures as needed, to choose from, later;
- technical understanding of how the digital camera works, what settings influence the image (many settings) and to what extent. Manual mode. Exposure triangle. Ambient exposure on top of artificial light exposure and so on;
- usage of artificial light and modifiers for that light, studio gear. Multiple light sources. Key-light, fill, rim-light, background-light. Light-stands, strobes, reflectors, soft-boxes, color gels, translucent diffusers, etc. See the strobist website for the Lighting-101 course;
- intent and ability to use the RAW image format (such as DNG) for extensive post-processing of digital images. Can be done at many different skill levels and in many different ways. There is a whole lot more to know (art & science & craft) than to use straight-out-of-camera JPGs. But many users are fine and very content with their JPGs.
- choice of background that shall not be distracting from the subject;
- choice of bokeh through positioning the subject further away from a background, choice of lens for the rendering and choice of a large aperture for shallow DOF - while keeping critical focus on the eyes;
- choice of how the final portrait will be presented: on print or on a digital screen - and then: how big, what physical size the image shall have and at what distance will the audience enjoy it - size matters!
- storytelling
- many more aspects that make or break a good portrait - even a tightly framed one...
