01-14-2009, 04:44 AM   #46
Class A's Avatar
But if the sensor is misaligned, I could easily see it throwing off those calculation such that the "usual" way of calculation how many turns of the screw to give for a given focal length, focus distance and focusing aperture might be off. In fact, I'd be *shocked* if the math happened to work out such that a single global adjustment actually fixed all lenses for all focus distances.
Just think of it this way: You can either correct a misaligned AF sensor by putting it in the right position (-> hardware fix) or by adding an offset to the focus mismatch it reports (-> software fix). If the software fix works this way (I present a simplified view on the matter, but in principle I assume this is what happens) then all the following calculations and actions happen as if the AF sensor were in the correct position.
01-14-2009, 04:50 AM   #47
Class A's Avatar
QuoteOriginally posted by Ben_Edict Quote
Because we also have really old F-lenses arround. These do sure not contain this detailed information (phase-correction), but focus just as any modern lens.
That's a very valid remark but as Marc one mentioned quite rightly is that usually there isn't a single cause for a problem. It could well be that some FF/BF problems are caused by smart lenses (why does "re-chipping" a lens would help otherwise? Or this this an operation that only helps Canikonians?) and other FF/BF problems have another cause. Not sure if anyone has ever investigated FF/BF (focus confirmation) issues with old manual lenses? Do they exhibit lens-specific behaviour as well or can they all be addressed by one body calibration?
I really think, the AF processing is done by the AF module on its own - at least with Pentax.
Yes, but that doesn't exclude the possibility that the AF system uses information provided by the lens.
01-14-2009, 05:37 PM   #48
Marc Sabatella's Avatar
Without knowing exactly how this works, I have no particular reason to believe the offset that would need to be added is constant across all focal lengths, focus distances, and focusing apertures. And if not, then indeed, it would require separate adjustment for each lens.
da35, ff, focus, k-mount, lens, pentax, pentax lens, question, slr lens, spot
Suggestion How about adding Focus Throw to lens details in the Lens database? brecklundin Site Suggestions and Help 4 08-16-2020 02:45 PM
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
Colour varies between applications nobbsie Digital Processing, Software, and Printing 0 09-23-2008 04:05 AM
All times are GMT -7. The time now is 06:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
