Originally posted by Paul the Sunman
I am currently travelling in Eastern Europe with the K3iii, DA 16-85, and four screw drive lenses (DA 15, 40, 70 Limiteds and HD DA 55-300 non-PLM). The DA 16-85 is driving me crazy. It auto-focuses fine for a while, and the images are very sharp. However, after a while it almost refuses to AF, despite excellent light, contrast, and structure in the subject. It should have no trouble at all, and the other lenses certainly don't. I try focusing on a subject, but there is no focus beep, and it is visually not in focus. I slightly move the focus point 10 or 20 times trying to get a "hit", and sometimes I eventually do. But sometimes I just give up.
I mostly use AF-S spot focus, or 5-point focus.
It "seems", though I can't be sure, that it improves for a while if I turn off the camera, remove the lens, and remount it. This may not be right, just a couple of random occurrences.
When I get back to Aus in a few weeks I'll test it on my K5 and K3, but for the moment I have no alternate camera.
The lens got a slight knock a couple of weeks ago when I tripped on a hike, and the hood hit to ground not-very-violently. I am not sure if this is responsible.
Has anyone else had AF problems with this lens/camera combination? Any suggested tests or fixes? I will get it checked at CRK when I get back to Australia if I can't figure it out.
Dirt in the contacts??? Try an alcohol-dipped swab.
