Originally posted by jumbleview Thanks everybody for responses. I like all of them, especially @Kerrowdown regarding A*135mm F1.8. But > $1000 for piece of optics is too much for me. I will look for something in 100-200 range. As of now I shoot KP mostly but think about getting K-1 in the future.
If you can stretch that budget just a little bit and find a copy of the SMC-F 135mm f/2.8, it has a better optical formula than the SMC-A version (4 elements in 4 groups, a very simple optical formula that usually appears in "budget" lenses, and is the exact same as the cheap Takumar Bayonet 135mm lenses). It would be worth it. The SMC-F 135mm f/2.8 has 8 elements in 7 groups - in other words, double the glass, which means a much better corrected lens.
Or, just get the SMC-M 100mm f/2.8 or the SMC-M 120mm f/2.8, that would be my suggestion. The SMC-M 150mm f/3.5 is also worth considering but it's f/3.5 and not f/2.8 - and it's not as sharp and contrasty wide open, at least my copy, so I don't usually use it below f/5.6. The SMC-M 100mm f/2.8 is perfectly usable wide open (my SMC-A 135mm f/2.8 wasn't, if there was any strong light in the picture).
