Originally posted by Belnan Thanks. I haven't got the debug option on the K3 to work yet. I'll try again, perhaps I missed something.
You don’t need to use debug on a k-3 the af fine adjustment is built into the firmware. Use the single lens option not the all lens option to have up to 20 data enabled lenses (f/fa/fa/DFA) adjustments remembered. Also bear in mind the adjustments typically are a combination of body and lens tolerances and aren’t likely identical across two bodies even with the same lens.
Edit: unless the maximum limit on setting fine adjustment isn’t enough.
