To address the original question: You should have those manual lenses, which you'd actually use to take pictures, which you otherwise would not. It's a 'would' not 'could'. That is highly dependent on your photographic interest and approach - even though
cases have been documented where interesting lenses have extended those considerably.
The manual lenses that I would not want to part with, because they have something special that I enjoy are the Irix 150mm and Laowa 100mm macros, the Voigtländer 20mm/3.5 ultra-compact super wide and the outstanding 12mm Samyang fisheye. I do own quite some others and while I e.g. sometimes cherish the rendering of my two adapted Carl Zeiss Jena lenses, I rarely use them and there are no Pentax lenses in the list. Both because Pentax managed to produce a range of AF lenses, that have an equally interesting or special appeal to me as some potential MF lenses, like the FA Ltd. series, and I simply enjoy the relative ease of use.
So what makes you like your M100/2.8? Is it the specific look, the process of taking pictures with it or the extension of photographic options on a tight budget? The answers may help to come up with good recommendations.
