Originally posted by robert ]I am ignorant on this subject so excuse me. Here are some photos of the lens and adapter. The lens
seems to work the same as my Pentax screwmount lenses with adapter. The few test photos I've taken seem
very sharp. I'm not sure what the A and M switch do as I just keep it on M. Is there a different adapter I can
use so I could use the bayonet mount? Thanks
Aaaah … ignorance accepted
Your lens is an Adapt-a-matic, not an Adaptall!
Adapt-a-matic lenses pre-date the Adaptall range.
This adaptor system is totally different to and in no way compatible with the Adaptall system.
Nevertheless the lenses are of good quality, both mechanically and optically … just a pity Tamron never made a K-mount for them.
So, yes, use it as you use your other M42 lenses, you'll not be disappointed.
The A/M switch allows for automatic aperture operation on M42 cameras with that capability, which unfortunately doesn't include any K-mount Pentax DSLR
Personally, when working in Manual Mode, I leave the lens on "A" for composition and focussing, to get the brightest viewfinder image, then simply operate the A/M switch to close down the aperture for metering with the Green Button and again at the point of exposure.
If you're happy working with the lens set to "M" and wriggling the aperture ring open and closed, fine. As long as the results are what you want
