Originally posted by pykeyuk For example, if i were to focus a bird of prey at 50 metres the lens would see it and then go out of focus and it does this on most things it's very frustrating as its a very expensive lens.
If it was my lens, I would test it and note the test conditions and the result of each test. If it is the lens AF that is confirmed to not work, I would return my lens to the seller with my documented tests (notes) explaining what the lens does , why it's not normal and why I want a refund / exchange if the lens doesn't work.
A few things to test, and note the test results or behaviour of the lens:
- I would do a simple test using a fixed test target to focus on, at a distance large enough so not to hit the minimum focus distance
- I would try to focus on the target using center point both thru the OVF and in live view mode, note the results.
- I would try to focus on a smooth surface without detail , such as a white wall, expecting the lens AF motor to perform a loop from infinity to nearest focus distance and back to infinity, to check that the AF motor system is able to cover the full range of focus of the lens
- I would then test if the focus limiter is doing its job. First, with lens focus inside the near focus zone, then with the lens focus limiter inside the far focus zone. I would observe and note the behaviour of the lens for each test.
- I would then test if the focus preset works. I would make the lens memorize a focus distance, then defocus the lens manual and press the focus preset button to see if the lens focus will go to memorized focus location. I would note the behaviour again.
If Autofocus doesn't work as expected it can come from the lens or the camera or both.
- To know if the lens is causing the problem or the camera, I would perform the test with the same lens on a different camera, and perform the same tests with the same camera with a different lens.
Then I would take my notes and go to the seller of the lens and explain the problem.
