12-21-2008, 10:30 AM   #1
problem in my DA* 300
I got my DA* 300 for a while. But today when I clean my len, I found that the apertures is not in a very good shape. One of them is in a wrong position which it's not in a perfect circle. Any impact on this? What can I do?
12-21-2008, 11:16 AM   #2
omega leader's Avatar
Warrenty
If its a DA*300mm then it is probably under warranty, check your credit card to see if you have extra coverage.
Send it in to get it fixed. It will screw up exposure, and impact the image quality.
12-21-2008, 01:49 PM   #3
Sean Nelson's Avatar
It's not unusual for this to occur on the very smallest apertures, but if the opening isn't pretty symmetrical by about f/11 or so then you should probably have it looked at.
For example, here's my 50mm f/1.4 at f/22. You can see that the edge of the opening at the upper right is nearly twice as long as the edge just counterclockwise from it. But I'd consider this quite acceptable for f/22.
12-21-2008, 08:32 PM   #4
roentarre's Avatar
Even the blade edges fringe in this Fa 50mm blades... Good capture to get so much details in this one though!
12-21-2008, 08:50 PM   #5
wlachan's Avatar
Depends on how bad it is. Of all the Pentax lenses that I have purchased in the last decade, none of them had perfect aperture shape. 2 of them were so bad I didn't buy one (FA135), and rearrange the other myself (FA77). Slight variations usually have no practical impact. My suggestion is for any lenses or cameras, if there is no practical concern, try to live with it if exchange is not an option because there is always a chance the techicans might mess it up further (techicans won't baby your gears they same way you do).
da*, k-mount, pentax lens, slr lens
Problem with Pentax DA 55-300 PeterEst Pentax SLR Lens Discussion 8 06-07-2014 07:52 PM
DA 55-300 - Problem or normal? mtngal Pentax SLR Lens Discussion 27 06-07-2014 07:46 PM
DA*300 + 2x teleconverter problem netuser Pentax SLR Lens Discussion 29 07-23-2009 07:08 AM
DA 55-300 filter problem? hamdala Pentax SLR Lens Discussion 4 07-16-2009 10:59 AM
SMC 300 f/4 problem - me or the lens? rfortson Pentax SLR Lens Discussion 7 12-27-2006 08:48 PM
All times are GMT -7. The time now is 05:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
