Originally posted by pschlute
I own the "K" version of this lens (optically identical) and it is certainly a lovely bit of kit to work with. However if you are expecting the whole frame to be equally sharp, you are going to be disappointed, The edges will be noticeably softer than the centre. Having said that, there is something going wrong with your image.The edges should not be "that" soft !
Can you link to an image on a site like Flickr, so we can see a full size image (unfortunately posting directly is no good as the forum resizes).
I suggest checking the infinity focus using Live View, magnified 100%. Same for closer objects. This will help to rule out a simple mis-focus. It is quite possible the lens has been dropped or taken apart and not reassembled correctly.
I took this image with the K 15mm 3.5 at f8 The edges are perfectly acceptable. Like sblake above, I just use hyperfocal distance with f8 and rarely try to actually focus the lens itself.
Hey Peter - iconic shot of the concorde nose - even the individual rivets are visible - at the edge too.
Sadly my lens is not doing anything close to that! Will pop a shot onto Flickr tomorrow and send the link.
Thanks for the input. I am starting to wonder if this lens was opened up and one of the elements put back incorrectly (eg a singlet put backwards could do this). No signs of dings and no dents or cracks visible on close inspection through the lens with a loupe against the light fully open. Also no separation, dendrites, haze, fungus or dust. Actually too clean for an old lens which suggests it may have possibly been opened up to clean out dust between elements. I got it 10 years ago from a dealer in Hamburg, Germany and its been in a controlled cabinet with my collection since then. (...when I got this lens there was not even a K1 on the horizon!).
No to find a lens element diagram so that my technician can open it up and compare!
PS I tried live view as well at close focused subject as well as distant - still the same characteristic, but worse on distant subjects than close subjects. Using LV looks like focus on the infinity hard lock position is about 2m (6ft) from the object focused in LV. Very strange - Perhaps supports the view that the lens has been opened and incorrectly reassembled.
Kind regards from cape Town, Alan
---------- Post added 09-20-22 at 12:35 PM ----------
Originally posted by pid
is there lens separation or smud on the backside lensgroupe?
Hi pid. No visible separation under close examination. No 'smud' on the back lensgroup either - elements appera very clean and clear.
