Originally posted by schnur07 I wonder if I should adjust some of the focus priority settings or the auto focus hold settings. I kind of switch back and forth between continuous AF and single AF. I'm not sure what my preference is. Maybe in low light, AFS would be the better option. And I'm sure I don't have very good technique. But it's a weird thing to try to get better at - not sure what I need to do to improve. It's not like practicing shooting a basketball where you get immediate feedback of whether you made the shot or not.
As with "birds-in-flight", one of my interests, it's all down to practice.
I've taken very many dozens of "generic seagull" pictures, in all sorts of lighting, wind and weather conditions, simply to get so familiar with my rig that when that once-in-a-season whatever flies past I've got a reasonable chance of getting it.
Don't just take pictures of games you're interested in, take every opportunity to take pictures of similar events in similar lighting so you've got more material to analyse and can then decide what are the best settings
for you!
Take sequences shots of suitable subjects at the various options available … A/F Hold, AF-S, AF-C etc. etc., make notes of what and which, then sit down at the computer and simply decide which settings suit you the best.
It's likely to take several sessions to start to see a pattern, but eventually (hopefully) you'll start to see a preference for a particular configuration … that's the one you can fine tune
Store it as a User Mode, so you always start from exactly the same settings, then if there's a further trend to a slightly higher shutter speed, a slightly different aperture or whatever it'll become obvious quite quickly and you can then modify your User Mode to suit.
I made the effort a few winters ago to diligently work through several years worth of exposures, making notes (from the EXIF) of the settings the camera had for exposures I was happy with, and when it was all plotted out 1/1500 @ f/8 auto-ISO (TAv Mode) became the obvious choice.
This is for me, using my "bigma" handheld, and I'll freely wind the shutter speed up or down or adjust the backlight compensation to suit individual circumstances, but I know where I'm starting from and that takes a lot of the guesswork out of it
Good luck
