Originally posted by Lord Lucan You must still be able use the reduced manual levels? Otherwise, the limitations are no different from the AF080C surely?
It is really lens dependent, an aperture ring on the older macro lenses make is much easier, however any of the newer lenses apertures are electronically controlled but don't work in reverse as well as the older lenses. The PTTL has limited manual exposure options down to 1/16th power and only gives full power on any of the auto settings, generally overexposing the subject even if -5 stops is dialled in on the body exposure
