Main reason is optics. The definition of F-stop is:
f/stop = focal length / diameter of effective aperture (entrance pupil) of the lens
The kit lens is 18-55mm f3.5-5.6. That's a 3 x zoom ie 3 x 18 = 54. There would nominally be a commensurate corresponding shift in F number of 3 stops. However lenses are typically designed to have a lesser change than the change in focal length would warrant. You can get an impression of how much you can zoom before the f-stop changes with the lens on the camera, metering off eg a white wall (an approximate measure, the camera exposure changes in steps of 1/2 or 1/3 stop depending on your camera settings).
Old film kit lenses were typically something like 28-70mm, =2.5x zoom, and f3.5-4.5 would have been pretty typical for these. I guess it was relatively straightforward to design these lenses like this, specifically because they were typically retrofocus designs with a large negative front element, so I guess the entrance pupil could also change while zooming through the wide angle focal range. There are also lenses where you can see the iris change size as you zoom.
