Wondering if anyone can offer their experience with this lens, or an otherwise informed opinion.
I was doing some tests of this lens (looking to choose between the 20mm M and A versions.) The test shots include south-facing sky in or near the frame, so they are a merciless test of any lenses coatings. But this lens showed quite a bit of veiling glare. So much so that I worried about it's general usability. So -- I checked the lens. It is free of fungus, but did have a bit of a fingerprint smudge on the rear element. I cleaned that off, and took some more test shots at different angles from the sun - with no real difference. While some shots are fine (great even), quite a few show localized blooming or veiling glare. In some cases, it seems that minor changes in angle or position will make the glare worse or better.
This isn't something mentioned in any of the reviews of this lens. There are many many sample images posted that look great (but so does my one sample shot almost 180 degrees from the sun.)
Here are more details of my tests:
- glare is apparent at every aperture
- tests were shot with a Pentax K1 (so sensor reflections should be expected to be worse than film)
- the lens was carefully shaded for all tests to prevent light from striking across the surface of the lens
I have attached samples below.
Any thoughts or experience with this lens would be appreciated.
