Originally posted by UncleVanya The large black shield is likely running into the sdm power zoom contacts. Remove the shield and try without it. You can safely cut the shield down and put it back without harming the lens if that’s the problem.
Originally posted by Not a Number A common problem with vintage third party lenses is indeed the aforementioned shield. However from the photos you posted the shield looks to be of the proper size. If it causes a problem typically the shield will much further on either side.
As you can see from my Lester-Dine (Kino) 100mm f2.8 macro that the shield doesn't appear to be any larger. The lens fits without problems on my K10D.
I estimate that it extends 5-6mm clockwise from the edge of the locking pin slot on the mount.
The shield can often be removed without major disassembly so you try removing it non-destructively as UncleVanya has suggested.
While this is usually the issue with vintage 3rd party lenses, I don't think that's the case here.
The pictures look like it has the short protection shield, furthermore would this not be a problem for the old K1000, as this is a MF camera only.
I think I can make out some dents in the images; maybe the lens was dropped on the lens mount and only unsuccessfully bent back.
If it was cheap you can try to bend it some more into shape, otherwise I would return it.
