I'm afraid that several answers haven't really taken the objectives into account and I'll stick to somewhat longer lenses ...
The LAOWA 2:1 100mm f/2.8 and the IRIX 150mm macro mentioned above are fairly large and heavy, but I use both. Whenever I want a lightweight setup (90mm+), I reach for the DFA100WR, usually also focusing manually (racking focus). Hard to beat: 49mm filter thread, excellent narrow hood protecting the lightweight inner plastic tube, excellent MF feel. Great as an all-around 100mm lens, just don't AF in life view. Best macro that I have in terms of high contrast handling. Bright viewfinder (/2.8), even though photographically, there's rarely a use for me at f/2.8. I mostly shoot close to/slightly beyond the diffraction limit. The two things I dislike are an unpleasant foreground blur and some LoCA/fringing.
From an optical construction, there was a
gradual refinement starting from an obviously new design with the A100/2.8 and continuing to date, given the announcements for an update to the DFA100WR (some used original DFAs may thus show up in the marketplace soon). While fine stopped down, older compact designs will not perform as well wide open and/or at long distances, limiting their general purpose usefulness. The simple M100/4 or A100/4 macros fall into that category as well as many 3rd party ones from that age such as e.g. the Elicar 90mm/2.5: It is sharp stopped down, but rather soft wide open and by Pentax standards extremely susceptible to flare, but the best 'classic' that I could find in terms of nice out-of-focus transition considering
both, foreground and background. Now superseded by the LAOWA 2:1 in my use.
My very lightweight travel setup is however a fitting achromat for the DA55-300plm, a combo which stopped-down
performs really well, with just a little more LoCA than dedicated macro lenses and for sure some field curvature or distortion, both fairly irrelevant in my use. And, to an extent, the most usable AF at macro distances that I have come across.
