Originally posted by volosong Just received delivery of a DA 20-40 f/2.8-4 Limited. On my Limited lenses, I prefer to use a snap-on cap instead of the supplied metal push-on cap with the "felt" inside.
Does anyone know what size cap will fit the lens hood? Based on the part number of the lens cap for the hood in the manual, (i.e., O-LW65A), I suspect it might be 65mm. The lens itself takes 55mm filters.
65 is probably correct from a quick measurement I took with a tape measure. The inside measurement of the hood looks closer to 64, I would imagine either may work. Sounds like a good idea, I may try that too.
