Originally posted by jslifoaw
I've also had limited luck using the 1.7x AFA with f5.6 or slower lenses. F4 is usually OK but F2.8 is ideal. I don't recall how the 150-450 does with the 1.7x, mostly because you lose AW, DC focusing, and automatic focal length for SR.
The 1.4x HD DA TC has none of those tradeoffs and is much newer - I expect it to be better but can't speak from experience.
The 1,7x AFA focus is a nice step forward on a manual lens, but a huge step back from the 150-450 AF: the screw drive of the AFA with its limited focus range is no competitor for the fast focus mechanism of the 150-450....(or any other focus lens), especially if you know the 150-450 works smooth with the 1,4x TC, there is no gain with the 1,7 imho.
Second thing: the 1,7x loses 1,5 stop of light compared to the1 stop of the 1,4x:
on a base lens of f5,6 adding 1,5 stop brings the autofocus sensor even more to the limits, even in nice daylight. Note that some newer bodies might perform slightly better but expect no miracles. Check the low light meter range in the dslr comparison tool, some meter down to -3EV others to 0 EV.
But don’t get me wrong: the 1,7x performs well , check here a recent shootout:
300mm plus Lens Club: discuss your long lenses - Page 2591 - PentaxForums.com
It is just that I don’t perceive the 1,7x as a step up from the 1,4x , it is more OR , depending on lens. On AF lens I prefer the 1,4x (and rather a bit cropping to match the 1,7x), on manual lens the1,7x .
