Congrats for getting your first Limited in the DA 21mm- it is indeed the most versatile limited prime for all-around use, and in being marvelously small. Great imaging, great carrying, especially with the KP! I've had my 21mm Ltd for over 10 years.
---------- Post added 11-03-22 at 10:58 AM ----------
Originally posted by que es tu I even envy my son for his DA 55-300 even though I have the HD version(red ring)!
Don't be envious. I had the non-HD version for years, even after the filter threads were damaged, then gave it away to friends along with my K-r and DA 18-55mm II lens after getting a great deal on a new K-S2. I wanted the WR factor in the newer HD version, and was surprised when I found its imaging was better, even sharper and with better contrast than the old one without the HD coatings. This difference was apparent when used on my K-5 II, with which I often used the older lens, or on the new K-S2. With the KP, I was also surprised to find its AF performance is better as well.
---------- Post added 11-03-22 at 11:06 AM ----------
Originally posted by que es tu I’m reading the posts and wondering just what it is that makes the limiteds so special? I mean what is the allure? I was intrigued by them when I first saw one, just the overall design is something special.
I have a bunch of Ltds. Some factors making them so special are- outstanding build quality, very fine imaging performance as powerful photographic tools in a very transportable, compact form.
---------- Post added 11-03-22 at 11:20 AM ----------
Originally posted by que es tu I used to have the 35 f2.4 and DA 50 f1.8, but never used them at that stage of my photography, so I sold them
I have the others lenses you have, and all are capable of very good bokeh. They are very good, very useful lenses. The DA 50mm f/1.8 you had is a marvelously inexpensive lens for portrait photography, as its FL is very good for this purpose as is its large f/1.8 aperture capability for controlling DOF- how much the background will be blurred to make your subject stand out more or not as much from it. It is also very useful for hand-held low-light purposes and for fast-action subjects as well. It can provide many times the shutter speed compared to other lenses of more average apertures. I have the FA 50mm f/1.7 instead, now for some 30 years.
I would suggest, the next eventual Limiteds for a very compact and very capable trio kit with your DA21mm, would be the DA 15mm and DA 70mm. I have both in the HD versions and they are absolutely great for small lens carrying and for tremendous imaging! The 15mm Ltd lives in the front accessory pouch of my holster-type camera case whether I'm carrying any other lens, whether zoom or prime, outside of another ultra-wide. When I need to go wider, it is already right there to serve! it is one marvelous little lens. The 70mm can deliver very fine results as a short tele prime with a pretty fast f/2.4 aperture for this FL and can deliver excellent edge-to-edge performance across the frame. Very good for portraits also.
