Originally posted by Athanassios If Pentax one day produces a wide 1.4 it’ll be my happy day.
Unfortunately, it would need to be very large and heavy, even if for APS-C, and very costly. Like telephoto also, with WA- as it goes wider it gets bigger and heavier, especially if also including a larger aperture, and will be much more expensive. Still not knowing the camera models you shoot with, these being a very important factor in dealing with what you are after- the camera model can make a huge difference in the outcome you can achieve. Your reluctance to go over ISO 800 indicates a reduced performance capability compared with later Pentax camera models. Just one stop of improvement means you can double your ISO settings with even better results in later models, as some could double that again and more.
The faster wide angle situation is one of the reasons a couple of years ago I decided to also get into FF and bought a new K-1 II. The price here in the US had dropped, making it actually less expensive than the new K-3 III! I got the kit package with the very fine-performing DFA 28-105mm lens at $100 USD off the lens cost, in addition to the price drop for the new camera. The K-1 II approximates the ISO capability of the new K-3 III by way of its accelerator being added in the mark II, and by way of having the basic advantage of a good FF sensor, which also has other aspects for potentially superior results. This decision was as an addition- still keeping my excellent APS-C equipment. Each has advantages. I also already had a number of excellent FF lenses from my 35mm film shooting days, which begged to be put back into service in FF capacity once again.
To give just one example here, as we've been discussing very good Sigma 24mm f/1.8 or Pentax FA* 24mm f/2 lenses as an option for your APS-C use. This is a workable option, though far from perfect. For one thing, these lenses, though very good, are not so good when it comes to the frame edge performance, which drops off more and more in getting farther away from the central area. Stopping down helps, but not getting into the "good" performance range in edge areas until at least f/4 or f/5.6 or so. 24mm provides a moderate wide angle similar to 35mm on a FF body. Then take the Pentax HD FA 35mm f/2, which provides a 'normal" angle of view on APS-C like a 50mm lens on a FF body, not WA at all. But on a FF body, it is the same as a 24mm lens on APS-C. Yet, this lens will blow away either of those 24mm lenses in performance. Very good to excellent sharpness edge-to-edge across the frame- even at wide open aperture! It has been updated, given a better build quality and with HD coatings, is compact and light to carry, and still at a reasonable price brand new!
Then with it on a K-1 II you have the additional image quality afforded by this FF model. You can shoot the same scene with any of those 24mm lenses on APS-C, and even if they were as good as the FA HD 35mm f/2 in edge-to-edge quality, you would then have a very fine 24mp image, but still could not equal the same shot and same framing as the FA HD 35mm on the K-1 II would provide, which would be a super-fine 36mp image.
I shoot with the excellent KP as my top APS-C body. It is also exceptional for higher ISO needs, though not to the degree as my K-1 II. It has its own advantages with the right lenses and is much more compact when I need that- which can be very important for me. At the same time, it is also far more advantageous in practical terms when it comes to telephoto needs. There are many examples where one or the other serves best.
All that is said to put forth awareness for the possible options that would bring definite improvement for your needs and possible future needs. Things to think about. Even if you decide to get the fine-performing Sigma 18-35mm f/1.8 lens ( not a bad idea), being able to mount it on a KP body would greatly enhance its advantages for image quality, including fine performance at much higher ISO, and would thereby be even far better than equal, compared to your wish for a WA f/1.4 lens on your current body, and at a more manageable size and cost. A perfect-condition KP could be had with some patience.
Important note! I just checked the PF test report of the Sigma 18-35mm f/1.8 "Art" lens which found this lens has severe problems with AF accuracy. They tried more than one copy supplied by Sigma, and with several Pentax camera bodies, all with similar results- AF was not dependable when performed through the VF. Really too bad, since in every other respect the lens is both unique and provides very fine sharpness when it is in focus. However, it is also very susceptible to flare in certain lighting situations.
