Originally posted by CarlosU In other words, the filter with the best posible coating can only be as good as having no filter (100% transmission, 0% reflection).
This is the most right-to-the-point and correct answer. It is also indicative, if wanting or needing a protective filter for a lens, this type is more expensive but is the way to go in order to avoid unwanted side-effects from the filter.
Some filters are formulated to deliberately alter imaging results. One such is the "skylight" filter, a type also often used as a protective filter, but it is formulated to cancel certain green or blue reflections to improve skin tones. It is then also useful for adding a slight warming effect without reducing incoming light to a meaningful degree, which can be a benefit for lenses otherwise having a "cold" or "clinical" look, which are otherwise good, sharp lenses.
---------- Post added 11-17-22 at 04:45 PM ----------
Originally posted by StiffLegged And where is anyone recognising that HD coated lenses are a step sharper than SMC coated lenses with the same optical design?
I was surprised years ago to find very noticeably improved performance from the new HD WR version of the DA 55-300mm f/4-5.8 WR lens when I got the newer one to have its WR advantage. As to test results, this improvement is again confirmed in the PF lens testing of the 3 basic kit lenses, the DA 18-55mm WR, against the two newer ones that are identical except for the HD coatings- the DA-L 18-50mm WR and the HD DA 18-55mm WR. Go to the top of the forum page, the "Lenses" category tab will bring down a menu which includes "Pentax Lens Reviews" to click on. Then scroll down to DA zoom lenses, then to the Pentax HD DA 18-50mm WR, then click on the button for the in-depth staff review.
This review is very thorough between these lenses, even at one point throwing in the well-regarded HD DA 16-85mm WR just for the sake of comparing against a much more expensive option. The Sharpness section of the review is very interesting. The end results were overall- better for the newer DA-L and the HD version of that lens, over the older DA 18-55mm WR. But the surprise for the testers was their finding of definitely better performance of the HD version over the other two. This was again stated in a paragraph of its own at the conclusion of the Sharpness testing. Based on my own experience with my two DA 55-300mm lenses and discovering the superiority of the HD version over its sibling, this was no surprise to me, but gratifying in that my observation was not a fluke.
It makes sense, because the HD coatings improve against factors that can cause a reduction in sharpness. I like the two newer lenses and their ultra-compact concept. I had the older DA 18-55mm II for years and gave it away to friends. I also found the new AF to be superior and more reliable, and I have been rather dismayed lately to find only the old DA 18-55mm WR model being offered.
