Did yesterday a test on seven Pentax Glasses with same exposure/settings ( f/4, ISO10000, 1/13s) on same "scene" with
IN ORDER OF APPEARANCE.
There are two "pairs" of seven photos taken with
DA*16-50/2.8 at @16mm
Limited HD 15/4 @...15mm
HD Macro 35/2.8 @....35
DA HD/RE 18-50 @ 18mm
Limited SMC 70/2.4 @ ....70
DA 50-200 @ 50 ( the WR)
HD DA 55-300 @ 55 ( the red)
In order to capture the same "scene" the 15-18 needed less than a feet away from the "glass". The 35er shy above a feet away, the 50-200 and 70 almost the same (!); some 1 1/2 feet away. Surprisingly the 55-300 did focus at less than 2 1/2-3 feet while Pentax says it need 5 feet. One more surprise is that the DA 50-200 was magnifying as much as the 70/2.4 at 50mm and more than the 55 at the red 55-300. Don't know why.
Findings:
First bunch of the 7 photos and without Photoshop "lens correction" vingetting and distortion was everywhere. And the DA* was as crappy as the RE HD 18-50 and no better than 50-200. Winners are the 35/2.8 and the 70/2.4 with less vingetting or crappy distortions. They behaved.
Second bunch of the next 7 photos ( same order of appearance) are with photoshop "lens correction" and things turned into detail and all "almost" looked the same save for texture and CA. Photoshop did some real magic.
BOTTOM LINE: the SMC Pentax Limited 70/2.4 gave the BEST IMAGES by far with our without photoshop. The fifth image in both first and second bunch is the 70/2.4 lens.
Yes, the test ignores everything and alot but in reality I wanted to capture a scene and at the end the SMC 70/2.4 was by far the best of the all. The texture eg on the iron jar on the left is magnificent.
(Soon I will do a better test at "day light" with 11 lenses among the most high rated in the forum".
PS: The tiff conversion of Pentaxes app, the Digital Camera Utility 5 is depressing. The saturation and contrast were as if I was shooting with a cheap Android phone. The iMac on the other hand, at mere "Preview" app was giving 99.99% same image as original DNG or like Photoshop and it's tiff ( no zip) was close to 200MB (16 bit) per file while Photoshop or Pentax's embarrassment for produce 144 MB.
PS: Why on earth Pentax's app does not have "lens callibration" for it's lenses. It's tragic!
This is not a professional test but the results shocked me. And yes, I hope you can see the differences at low Kb Pentaxforum images and share with me your ideas.
