Originally posted by Jomar Honestly, I didn't even realize that the DFA 21 was designed for FF use. I just thought it was an improved version of the DA 21. I know that the DFA is weather-sealed while the DA isn't, & I just assumed that was just one of the many improvements the DFA 21 had over the DA 21.
I suggest you read the in-depth review of the DFA 21, I think and hope you'll find enough information in there to determine if it's the lens for you. Based on what you write, I think the K-3 III is probably a better upgrade path than the new 21mm but it truly depends on your use case, what you find lacking in your current setup, what you want to do but can't.
There's also a review of the K-3 iii that you might find useful
