Originally posted by Lowell Goudge Any comments.
My initial thought is that a camera is not perhaps the best device to test this with. Apart from the obvious 1/2 stop or 1/3 stop setting, the main issue is going to be the ISO rating. While I understand that Pentax cameras have always been very close in this regard, I have seen reports that different camera from other makes can vary up to one stop even within the same brand for the same ISO setting.
Regarding green button exposure with non-A lenses you have another issue. The meter itself can only read what is transmitted through the focus screen (unless using solely LV). Anyone who has owned a camera from the K10D era will tell you that the new brighter screen from that and similar models could be woefully inaccurate depending on the f-stop used, when using manual aperture lenses.
Personally I find that the adjustments available to us in the digital era make it pretty irrelevant if a lens tends to over or under expose based on the same f-stop setting.
