Originally posted by filmamigo Hi folks - I ran across an interesting comment in the lens reviews for the Pentax-A 20mm. Rather than reply to the original poster, I thought I would ask everybody to try and explain the comment.
@torashi ... Make sure your copy [of the lens] has a calibrated aperture (only relevant if you're shooting it in the A position).
I always assumed that Pentax-A lenses were similar to Nikon Ai-S lenses, with the aperture mechanism linearized and optimized for automatic (aperture priority or program) operation.
Can anyone elaborate on what the specific concern is? Is calibrating apertures something done with a lens service? Is this only applicable to Pentax-A lenses, or to all A, F, FA and above?
Please tell me anything you can about calibrated apertures!
Thanks
I think it is a load of BS.
As other posters have explained, the lens should have a linear movement of stops vs position so that the body controls the aperture correctly, however having said that, you can and should check exposure linearity of the lens/camera combo, by taking a sequence of shots at a uniform surface (I use block walls, sidewalks or paved roads) with each and every aperture and then measure the average greyscale value of the shots. It should be close to 128
Although most lenses will produce a very flat exposure vs aperture, sometimes you can have errors in the forst or last stop positions. I have also experienced one lens,[Tamron XR di 28-75/2.8) that had an exposure error drifting from 1/2 stop over exposed wide open to 1/2 stop under exposed when stopped down.
I have also with some bodies, notably K10 and K1MKII , where addition of a teleconverter requires some exposure adjustment because the reported aperture is not the same as the effective aperture. The K10 was notorious for this, and I found the K1 was similar. The *istD, K7 and K5 did not have this issue.
