Originally posted by que es tu
The term “telephoto landscape” has always intrigued me as it seems like a contradiction of terms! Would this be considered a telephoto landscape?
To a degree we have been programmed into thinking that "landscape" means wide angle lenses and sweeping views of of massive vistas. When I was shooting 4x5 film, my favourite landscape lens was the Nikkor 210mm f5.6, which gave a field of view similar to a 70mm lens on 35mm or a 50mm lens on APS-C, and often I cropped those images down to a similar field of view as a 105mm on 35mm or it's 70mm field of view equivalent on APS-C. My ideal landscape lens on the 4x5 format would have been 300mm, but I was never able to talk myself into spending the $$.
Now I tend to shoot a lot of my landscapes with the DFA* 85/1.4, and often crop in a little bit, bringing me closer to the angle of view you would get with the 70mm lens on APS-C.
Its easy to pigeon hole "landscape" photography as must be shot with a wide angle to include as much as possible, but more often than not there are better pictures within that sweeping vista that can be plucked out with a telephoto lens.
I just checked my Lightroom catalogue, and it seems I rarely use wide angle lenses in landscape photography, most of my pictures are taken with lenses ranging from the 50mm standard (I use a K1) up to about 150mm. Less than 10% of my landscapes fall outside of that focal length range, and less than half of that are wide angle shots.
Anyway, that's just my experience, but the point is, there is a very strong case to be made that landscapes are not the exclusive domain of wide angle lenses.
