That grub screw needs to be loosened to allow you to unscrew the front end. Then you will be able to see the 3 screws that hold the focus ring/distance scale ring. You will need a very small jewellers/modellers screwdriver (I have a cheap modellers screwdriver kit and filed down the smallest flathead bit) or eg a Starrett. A drop of nail varnish remover is good to soften any thread locker. It takes feel to get these small screws, carefully apply turning pressure while pressing very firmly to engage the screwdriver in the slot. You do not want to break the top end of the screw! If it's stubborn try warming it up with a hair dryer or hot air gun.
