So I know this post might be met with a lot of comments accusing me of blasphemy but here it goes... I do not shoot on Pentax bodies (DSLR or film) and have adapted my 3 Pentax lenses so far to my Canon EOS M (I have a SMC Pentax-M 50mm f1.7 also a 28mm f2.8 and now a Vivitar VS1 70-210 f3.5 Kino (SN 22nnnnnn). In order to fit the lenses on the Viltrox EF->EFM adapter the aperture control pin and shield had to be trimmed back (*GASP*). Suffice to say on the two SMC Pentax-M lenses I was able to do this with the lenses fully assembled and kind of hackishly chopped it off with some flush cutters as the shields were plastic.
On the Vivatar the aperture pin was protected by a metal shield not plastic and seemed so close to the rear lens elements I decided to remove the 5 screws holding the back mount. With the mount off I was able to easily use the dremel to remove the shield and pin. When I reassembled it I took some shots and everything seemed great, that is until I attempted to adjust the aperture and realized it was completely seized. I took it apart again and looked at the mechanism a bit more carefully. Suffice to say after an hour and half last night I realized I have no idea what I'm doing. It nearly seems like it's indexed in some particular way and will require a bit more know how than I have to reassemble this. I did have it working to a point but it seemed like I was missing some aperture stops towards the stopped down side.
I can post pictures, video...etc, if someone believes they might be able to help save this lens. From the 5 minutes I did get to shoot with this it looked amazing. I'd be willing to go on a Zoom call if someone thinks they can walk me through this.
