Originally posted by Michael Piziak
I think it would be *very* useful to all Pentax users that are considering reflex lens, that is if you would make your review of owning the lens here on Pentaxforums - please do so friend....
Also, I wander if you perhaps may have had a lemon copy of it - ? I'm particularly concerned with the mount to the Pentax k and wander if it makes a bad connection like you experienced with the Minolta....
Michael
---------- Post added 02-04-23 at 07:07 PM ----------
Wow, your copy of the Sigma seems to deliver better, or sharper I should say, photos than the Pentax 400-600mm.
I am somewhat scared away from this lens, though, after reading Richard L. posted above. Do you have any similar negative comments about it? Do you think maybe he came across a lemon copy ?
I don't consider my 400-600 to be less sharp than the Sigma. What you are seeing in the results is probably user error - it is so easy to slightly miss focus. Also an extra stop of noise denoised will soften things a little at this level.
A lot of people are negative of mirror lenses. The lenses are intolerant beasties that will punish you for the slightest misfocus - I did a thread with a theory on it not long ago -
Mirror Lens Depth of Field - PentaxForums.com
Note that I wouldn't think of trying to nail the focus with the OVF. I tend to use live view and if handheld with a viewfinder loupe. But imagine if you are trying to handhold a refractor 600mm.
I also tend to work at base iso and pull up the image in post - this means I keep absolute control of the highlights which aids in keeping good contrast.
I use full frame and try to avoid cropping too much because sharpness is marginal - this doesn't bode well for using it on APSC.
Having said that here is the 400 - 600 on the Q (#1109)
Adapted lenses tested on the Q : the reference thread - Page 74 - PentaxForums.com Now that is cruel and unusual punishment for a lens !
If you are planning to use it as in your OP you can prefocus a little - just be aware that merely being at the bird feeder may not place the bird in the plane of focus.
A lot of the success of your endeavour will be in the aethetics of your background - a bunch of donuts probably won't do it for you - you need an un- contrasty background.
