Here's a focusing problem I found using the K3-III and the60-250mm. Trying out the lens today, after not using it for a while, it would not autofocus. The lens would make a slight squealing sound when trying to autofocus and the distance scale would only move slightly between the 2m and1.1m mark. The same behaviour occurred when I tried to use quick shift or by putting the lens focus switch to MF.
Oddly enough, when I set the camera body focus switch to MF it would allow full manual focus. When I removed the lens from the camera I could also now get full distance scale movement using the focusing ring.
I cleaned the contacts on both lens and body with no effect. There is no damage on the lens contacts and all seems physically OK. The K3-III has the latest firmware and I have not had any issues in the past with this lens.
My first thought was SDM failure but the fact that it tried to autofocus, and that it would only manual focus using the camera body switch or when it is disconnected, was really odd.
So I got out my old K3 and tried that. Autofocus was back working again. When I put the lens back on the K3-III full autofocus and manual focus were also working again.
I don't know what caused the issue, I had a fully charged battery in the camera, but at least it's working now. Has anyone else had similar strange issues with this or other lenses?
Reason: Formatting
