Any of the Tamron Adaptall-2 primes (I've yet to obtain a 17mm), but the 24mm, the 28mm, the acclaimed 90mm and the 135mm (all f/2.5) are faultless … in my opinion. I've also yet to "assess" the 200mm f/3.5, though I doubt I'll be disappointed. The 500mm mirror can be an acquired taste, but perfectly good for what it is.
I've only got the 28mm f/2.8 from the earlier Adaptall range … no problems to note, but I've only used it on film.
The Adaptall mounts can get a little stiff, with age … one of the few occasions with camera equipment where a quick squirt of WD40 can prove beneficial
… but leave it all dry out a bit before mounting it on the lens!
I've tried the Petri 28mm f/2 and the Kiron 28mm f/2 for "astro" work … both suffer from coma to a degree when wide open.
Some of the old Soligor pre-set T2-mount lenses can prove surprising … I particularly like the 35mm f/2.8.
The Riconar 55mm f/2.2 can give "interesting" bokeh effects, if you're into that sort of thing.
The Vivitar TX range are all solid performers … finding a PK adaptor at a "sensible" price can be the stumbling point.
Originally posted by MrclSchprs ... but nevertheless stop down metering only. And that is a bit of a pain in the butt.
Don't let stop-down metering hold you back … practice, embrace it and enjoy the world of M42 lenses, with the appropriate adaptor … there you'll find some real gems
Enjoy
