Originally posted by krilun Hello I need some help fixing my Fujinon lense. I cannot take it appart. The focus ring is loose and I can't expand the helioid. I can't find anything online about how to take a part of this lens. Any advice would be appreciated.
Welcome, krilun. The inside of my Fujinon 55 f/1.8 doesn't look the same as yours. But I'll describe how to loosen or tighten the focus ring on my lens in case it may be helpful.
First, use a friction tool to remove the lens name ring / bezel.
Next, use a lens spanner to remove the front elements group.
Now three screws can be loosened to detach the upper barrel / filter ring.
" target="_blank">
When the upper barrel piece is removed, now four screws are accessible which attach the focus ring to the brass focus helicoid. Each screw has a small washer - be careful not to lose them.
(Just rotate the outer focus ring to uncover the hidden screw.)
" target="_blank">
" target="_blank">
