12-31-2008, 03:38 AM   #1
jfsavage's Avatar
Aspherical Pentax Lenses
Do any of the Pentax lenses include aspherical elements?
12-31-2008, 04:36 AM   #2
8540tomg's Avatar
Many Pentax lenses have contained aspheric elements as far back as the K series of the mid 70s. Bojidar Dimitrov's Pentax page documents this quite well:
Pentax K-Mount Lenses and Lens Accessories
Consult his listings for any lens you may be curious about.
Cheers,
Tom G
12-31-2008, 07:26 AM   #3
I've got the SMC 15mm f/3.5 aspherical...it's a pretty good lens.
12-31-2008, 07:31 AM   #4
Banned
QuoteOriginally posted by mabelsound Quote
and a very rare lens.
12-31-2008, 07:44 AM   #5
I;ve got that lens too, excellent apart from the massive fungus problem. One day i will investigate but it seems like a pretty big task...
Anyway, as far as i can tell it was one of the first aspherical lenses pentax made and my grandfather paid a lot of money for it.
12-31-2008, 07:46 AM   #6
Yes, I was shocked when I realized it was the really rare version! You'll hate hearing this, but I got it for $100 on Craigslist from a guy who was switching to Nikon.
It is soft at the corners and exhibits heavy flare. It's also freaking huge. But I love to use it--it's very weird.
12-31-2008, 09:29 AM   #7
pentax usually do not divulge whether or not their lenses have aspherical elements
one rare exception is the FA31 which has "AL" in the name
12-31-2008, 09:50 AM   #8
Banned
I do hate hearing that.. but good for you! lovely photos by the way.
12-31-2008, 10:00 AM   #9
8540tomg's Avatar
Mabelsound
I love stories like that. I hope to be able to tell one just like it some day! It would be even better if I could make an identical find to the one you did. The K 15mm is very high on my wish list.
Cheers,
Tom G
12-31-2008, 10:17 AM   #10
rburgoss's Avatar
From the lenses I have or had, I do remember the following
FA*24/2 (still have) was advertized as having aspherical elements. If fact, the aspherical element is not glass but some exotic resing.
FA 28/105 aspherical
FA 28/70 f/4
I do have an SMC-A 15/3.5 but I don't think mine is aspherical. I have never seen it and the only versions I know off are the A and non A versions.
12-31-2008, 10:24 AM   #11
Otis Memorial Pentaxian
QuoteOriginally posted by k100d Quote
As noted above, modern Pentax lenses with aspheric elements generally have AL in the lens name inscribed on the barrel or face.
Here is a short list of the lenses I am aware of:
  • DA 18-55/3.5-5.6 (yes, the kit lens has an aspheric element)
  • FA 31/1.8 Limited
  • FA 35/2
  • DA* 16-50
  • DA 12-24/4
  • DA 16-45/4
  • DA 17-70/4
  • DA 21/3.2 Limited
It should be noted that aspheric elements are relatively rare in older lenses due to limitations in the manufacturing technique. At one time, hand-grinding was required by highly skilled craftsmen and aspheric elements were only found in fairly exotic lenses. Due to modern technology, this is no longer the case. They are relatively common in modern lenses and really have no particular significance except to indicate that the lens "may" have a more sophisticated design or "may" be better corrected than a similar lens from another manufacturer.
12-31-2008, 10:40 AM   #12
jeffkpotter
Guest
Unfortunately "aspherical" does not always mean better. It is said that lenses that have aspherical glass have fewer elements and that reduces interior reflection and gives you a lighter lens. It also makes a lens cheaper to manufacture. So in some cases aspherical lens elements do improve the quality of a lens, but in other instances you get a poorer quality lens that is essentially more cheaply made than an older non-aspherical model. You really need to know your lenses! Most cell phone cameras have aspherical lenses and that doesn't make them great.
Great shots above!
12-31-2008, 11:20 AM   #13
aspherical elements are sometimes noted to deteriorate the quality of bokeh as well, if you frequent leica forums, they note certain lenses as Pre-ASPH
12-31-2008, 11:24 AM   #14
RaduA
Guest
I think a lot of us will be interested in a head to head test of this lens with the future DA15/4 Ltd. Although I honestly think that 30 some years of technological advances will shaw pretty quickly.
Radu
12-31-2008, 01:26 PM   #15
I strongly suspect the DA15 will be better. I did test the SMC15 asph against the Sigma 10-20 at 15mm, and the Sigma was significantly better at the corners.
The nice thing about the SMC15, though, is that it's full frame, and I can use it on film, as in the above pics. I'm sure the DA15 will vignette on film...
One other great thing about the SMC15 is the built-in filters. For the second photo above, I had the red filter engaged...really handy for dramatic skies!
k-mount, lenses, pentax, pentax lens, slr lens
Canon FD 85mm F1.2 S.S.C. Aspherical on Pentax Asahiflex Pentax SLR Lens Discussion 15 10-22-2010 09:35 AM
Aspherical lenses any good? Silverkarn Pentax SLR Lens Discussion 21 09-03-2010 01:10 PM
Sigma 20mm 20 f/1.8 EX Aspherical DG DF AF for Pentax nezih Pentax SLR Lens Discussion 6 01-30-2010 07:50 AM
Pentax Kx + Tamron sp af 17-50mm f/2.8 xr ld aspherical henrywmk Pentax SLR Lens Discussion 0 01-01-2010 04:37 AM
All times are GMT -7. The time now is 12:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
