Well, you have stated aperture speed is important, so this eliminates the otherwise very good-performing Pentax HD DA 18-50mm f/4-5.6 DC WR lens or the DA 16-45mm f/4 as well. When you need the f/2.8 aperture or close to it, this is important. One other possiblity is the HD DA 20-40mm f/2.8-4mm Limited. Fine imaging, but of shorter zoom range, it offers f/2.8 at the short end and just one stop off at the long end. it has steller build quality, and WR, but it offers much more compactness compared to others having an aperture of f/2.8 capability. In fact, it is my preferred choice for compact carrying. However, as UncleVanya says, not very budget. This is a premium Limited lens.
Otherwise, I too recommend the Sigma 17-50mm f/2.8 EX DC HSM lens if you can find one in perfect condition. Well-built, well-designed, excellent imaging. I have all but the DA 16-45mm of these lenses.
---------- Post added 04-05-23 at 08:07 PM ----------
Originally posted by ramseybuckeye I had a Sigma 17-50 2.8 and used it a lot a few years ago. It was a good lens, as long as you didn’t shoot wide open. However I needed a weather resistant lens and got the Pentax 20-40 which ended up replacing it. Again, the Sigma is good, but it’s quite a chunky lens for not really being a usable 2.8, but then maybe that was just my copy.
Yes, another reason I often choose to go with the HD DA 20-40mm f/2.8-4 DC WR Ltd. And it is probably better than most for avoiding flair for improved clarity. The Sigma 17-50mm is chunky, but not for its range and what it can do. It is actually sharper wide open than the older Pentax DA* 16-50mm f/2.8, but as far as shooting at f/2.8 with this Sigma lens, just a tad of stop-down to f/3.2 makes for a big imiprovement! The Tamron was shown to underexpose slightly, making it actualy f/3.2 anyway, and it has very high field curvature. OTOH, the Sigma 17-50mm has been tested as having essentially zero field curvature, which is remarkable for any lens, especially a zoom lens with WA capabilities.
