Originally posted by Not a Number Did you take the focus helicoid apart or not? If you did not and have the focus barrel/ring secured set to infinity. Remove the focus barrel and look through the viewfinder and check the focus on an object far enough away to be considered infinity. Adjust the focus turning the helicoid barrel. Once it is set replace the focus barrel aligning the infinity mark. Tighten down one of the barrel retaining screws and check infinity and close focus. If it looks good tighten down the rest of the screws and re-assemble the rest of the lens. If not, remove the focus barrel again and readjust.
If you took apart the helical and you can't get infinity with the above procedure then you probably have to take the helical apart and try to find the correct entry point. This is a trial and error process if you didn't mark the positions at the point where you separated the helicoid. Even with markings it can sometimes be trial and error.
Note: moved to the SLR Lens Discussion section.
Thank you. I did not take the focus helicoid apart. I will try what you suggested and let you know. Thanks again.
---------- Post added 04-06-23 at 12:03 PM ----------
Did what you suggested. Pointed the camera to an object 50 meters away. Turned the focusing mechanism, still won't focus, it's always blurry. As I have explained previously, I don't think I have changed any elements order, I did take out the front assembly whole, the focusing ring and at the back I did unscrew the last lens at the rear but put it back the way it was. There is something I am missing, I don't know what it is.
I did make another video showing the way I move the focusing mechanism and a general view to see if that helps cast some light.
Thank you kindly
