Originally posted by UncleVanya That's a nice lens that I also own. I'm not sure its in the same league as the DFA 70-200 however.
I should have qualified my statement better than I did. I meant to say, I prefer my DA* 50-135mm f/2.8 (on my KP) rather than going for a DFA* 70-200mm f/2.8 (on my K-1 II). Of course I know I would definitely get even better resolution with the DFA lens on my K-1 II, more so because of a 50% resolution increase from the 36mp K-1 II when taking the same framed shot using the 70-200mm vs the 50-135mm on the KP. No question. But I have considered, how often would I really reach for my K-1 II and the blunderbuss DFA* 70-200mm over my KP with DA* 50-135mm setup?? It would most often be the KP setup of course, and that lens is so compact and easy to grab and carry! And the quality I'm getting from it is extremely satisfactory. Even then, I mainly use it when I need some tele work in conditions where the f.2,8 capability will be important, or its own size and weight factor is no problem, and again I love the quality imaging it gives me. Otherwise, turning to the 55-300mm for many circumstances, along with say the DA 20-40mm Ltd is a great way to go.
Some are suggesting the 55-300mm PLM. I think a good suggestion- unless one needs the f/2.8 capability! Must remember as far as capability and quality too, what is wide open with a 55-300mm is stopped down with f/2.8 lenses. I have the HD DA 55-300mm WR, whch delivers good enough AF for me on my KP. But it cannot replace my DA* 50-135mm f/2.8 lens! My DA* 200mm is also a wonderful lens to round out my Sigma 17-50 f/2.8 EX DC HSM, Pentax DA* 50-135mm f/2.8 combo. If I need WR all the way through, I compromise some speed and WA in having the Pentax 20-40mm Ltd at the short end.
Therefore, from my point of view, having the DA 55-300mm PLM to handle many situations, along WITH the premium kit- the DA* 50-135mm f/2.8 plus TC, AND the DA* 200mm f/2.8 would provide two great alternative kits for APS-C use.
I would recommend this over the DA* 60-250mm, as not having the f/2.8 advantage, is quite large and heavy, and risky in not being able to convert to screw-driven if SDM fails.
