For a new to manual focus, and manual exposure, you may find a non A lens frustrating. On many Pentax bodies, (I can’t speak of the K70 directly) the green button metering is not consistent across all apertures. There have been many posts over the years on this topic.
Years ago I posted this curve that shows the difference between f stop and exposure on different bodies.
To explain the graph,
Different lenses and cameras were used (some of which I won, some of which other forum members contributed to in the process). What was found to be consistent was that exposure was almost perfect in the F4-F5.6 range, which makes sense because virtually all consumer kit lenses etc are in that aperture range.
As manual lenses meter in stopped down mode, you can see the true performance of a lens at each aperture. In automatic aperture mode as shown by the A 50/1.2 the exposure is perfect, this is because the camera knows not only the native aperture, but also the curve of aperture vs metering performance (assumption on my part but the evidence speaks for itself) and compensates accordingly.
If you are going to use a non A lens, you need to measure this performance for your lens and camera, or, just take a shot if a uniformly lit monochrome subject, (sidewalks, roads, block walls and tree trunks are all good) and adjust your exposure to be centered on the histogram
