I use my DA 20-40 with the attached 55mm "hood". Mine has a deep metal lens cap which fits over this, but which unfortunately has got damaged, so I want another
I know the little hood is MH RA 55 (it says so on side)
I know that the O-LW65A is the standard metal cap (Pentax told me) for use as a lens cap without the 55mm
But I don't know what lens cap will fit the lens with the 55mm attached
anyone point me in the right direction please?
