Originally posted by Wheatfield The point Richard makes that even a crappy lens is able to produce a good picture is true. One has to identify what the lens doesn't do well and take steps to not put it in a position where it will fail.
The lower quality the lens is, the harder one will work to find out what it excels at (if it actually excels at anything) and limit one's picture taking with that lens to what it's OK for.
The problem is that for one photographer, what the lens does well might happily dovetail nicely with his or her style of photography, while for another, it might not be capable of doing the job at all.
One of the worst lenses I have owned was a Nikkor 50/1.2. It wasn't sharp at any aperture, but at the time I was doing a lot of boudoir photography and I found it to be a very good fit for that style of work where it's "romantic softness" was a desirable trait. I never had to use a Softar with that lens, it was a built in feature.
If I needed a sharper 50, I had a Series E 50/1.8 that was remarkably good considering it's price point.
Fast forward to more recent times and I found the FA50/1.4 to be a decent enough lens in the studio on APS-C, but as time marched on I was doing more and more non portrait photography and it became a focal length I rarely used on that format.
When I moved to the K1 I found it to be a less than adequate standard lens for the same reasons the OP is seeing (soft at wide apertures and veiling flare that a lens shade doesn't cure). Fortunately for me I had several other 50mm lenses that performed far better, albeit all manual focus, and when the DFA*50/1.4 came along I ditched the FA lens once and for all. I didn't like the compromises it forced on me to make it work to the standard I wanted.
Saying any lens in the right hands will make a good picture is a rather sanctimonious and self aggrandizing statement that implies the photographer is at fault for the failings of the equipment. If the equipment isn't capable of doing what the photographer needs it to do because the equipment weaknesses are sitting squarely in the zone of what the photographer needs it to do well, it's the equipment, not the photographer and he or she needs to find something that works for what he or she is doing.
For me, the FA 50 doesn't work, not because I can't make a good picture with it, but because I don't often do the few things it is passably good at. I moved to the DFA* lens because it performs well at what I do and it runs circles around the best the FA lens can give me.
Do you still do some boudoir with your DFA*50/1.4? I shoot models and i am considering this lens BUT it has to be able to AF properly in AF-C on the outer focusing points.I would also ask if the 50* 1.4 SDM focus is good in low light as outdoor at night in a city?(Artificial light but not great light.I have a K-3 III Mono by the way (firmware V2.0).
My recently purchased DA* 16-50 2.8 PLM was a nightmare regarding AF so i returned it and i don't have any desire to buy another one.It was a dud obviously but the QC doesn't seem to be very good for such an expensive lens (DA* 16-50).
What about the "new"? HD FA 50 1.4 with the new coatings?Does anyone tried that lens?Thanks.
