Originally posted by Athanassios Why not tell us about your opinion of how your image looks like without any post processing? My opinion is about RAW images converted into photo files and our base file in this lens is bad. Very bad. Unless you think that eg the softness of the rose outdoors wide open is salvageable by pp. it’s not.
Originally posted by BigMackCam I'm on my tablet and away from my computer right now, but when I get home I'll happily share before and after shots that show the untouched raw file and tiny adjustments that transformed it into a perfectly useable image.
Truth be told, most "mass market" enthusiast-oriented fast fifties from the film era aren't great wide open, and benefit from being stopped down to at least f/2.8. I have a Minolta AF equivalent that I use on Sony A-mount, which performs similarly. They all do, more or less... and all would have a difficult time with that rose in such harsh lighting with blown highlights. I suspect you'd have got better results by reducing the exposure one or two stops and lifting shadows as necessary...
OK... as promised:
Here's the untouched raw file, loaded into RawTherapee, followed by the 1:1 crop:
As expected with this type and vintage of lens, it's soft and lacking in contrast when shot wide open - but the
detail isn't lacking... it's all there, it just needs to be teased out; and that's
easy. I enabled RawTherapee's default level of Capture Sharpening, default level of Unsharp Mask Sharpening (set to sharpen edges only), and default level of Local Contrast. No clever fiddling around... No heavy post-processing... just the default values on three commonly-used tools:
... which resulted in this:
Looks much better, doesn't it? And the adjustments really were minimal.
BUT, "
the lens is horrible wide open without post-processing!!", you say? Well, let's be clear - there are
plenty of very modern lenses for various systems that rely heavily on hidden in-lens / in-camera processing to deliver good-looking images - but we don't see how "bad"
those lenses are optically, because the processing has already been done
before the raw files are produced, and it's baked in. The only difference between them and the FA50/1.4 examples above is, I'm doing the (very simple) processing in post.
I highly recommend
LensTip's 2010 review of the FA50/1.4. Some take-away comments from the review include:
Quote: Usually the ordinary classic 50 mm lenses are one of the sharpest devices in any system. In the f/4-f/8 aperture range they give results even high-end zoom instruments can only dream about.
Quote: The Pentax performs very well here. Some reservations you can have when it comes to the image quality at the maximum relative aperture but every 50 mm device experiences some problems there. By f/2.0 we see the situation improve a lot in the frame centre but you can express still some serious reservations about the edges. Only by f/2.8 we get a very good sharpness both at the edge and in the centre.
Quote: the overall performance of the lens should be assessed as good.
Quote: Up from f/2.8 aperture the lens generates outstandingly sharp images. By f/2.0 you can have some reservations about the frame edge and inadequate lighting conditions certainly might make some photographers use f/1.4. Doing so, they will not be exactly happy with the results but they can’t complain either because for this price the competitors offer you nothing better.
Now, that review
is 13 years old, and technology
has moved on considerably in terms of sensor resolution and optical design - which is why we have modern, high-performing beasts such as the D FA*50/1.4; but for those who understand what they're buying - i.e. a film-era fast fifty with performance appropriate to its class, and the ability to capture excellent images
when used to its strengths - the original SMC, new Classic and new HD variants of the FA50/1.4 still offer good performance at the price. You just have to understand what you're dealing with, the limitations therein, and set your expectations accordingly.
Going back to your suggestion...
... I'd say it looks exactly as I'd expect from an instrument of this class and vintage... and even though its comfort zone is f/2.8 onwards (arguably,
f/4 onwards for
best results), I say it's absolutely possible to get excellent images from it at wider apertures - even wide open - with little effort, a bit of forethought and very minor post-processing. That's just
my opinion, though... Each to their own.
One of your test images - the rose photo at f/1.4 - would be a challenge for many older, fast lenses wide open due to the blown highlights contrasted with darker background (that's classic blooming / fringing territory, right there). Others - the "sun at the front" blue turtle and especially the green eyes, both at f/1.4 - aren't accurately focused (no offence intended - it can be tricky with fast glass, I know). So, whilst I accept you don't like the performance of the lens (and that's fine), I wouldn't want folks considering buying one to think that's all it's capable of...
