Originally posted by UncleVanya My main point is that you can easily fix the vignetting at wide open if it bothers you.
And please don’t take what I said about the focal lengths wrong. I’ve had people who thought an apsc 28mm would act different than a ff 28mm on the same apsc camera. They both give the same rough angle of view on the same apsc camera. Done adding the ff lens is different and that’s what causes it. I apologize if that seemed too picky.
No worries, I accept my confusion about focal lengths and the general problem of how to explain it to a novice. I just go by the page
here that says that a FF lens (Señor 43, for example) on my borrowed K-1 II will have a FOV of 53 ° / 45 ° and on my K-3 III, my K-r, My K-30 and my 2 K-01s it will have a FOV of 37 ° / 31 °. Those numbers are different, therefore Señor 43 gives different results on a FF vs an APS-C camera. What the correct terminology to use when explaining it is a problem for me, so I default to using incorrect terminology.
It will still be a 43 mm lens and it even has a 43 printed right on it to remind me what it is.
I also know that putting my beloved 18-135 on my borrowed K-1 II
might be problematic, but putting my 28-105 on my K-3 III is okie dokey.
So because of that, any future LBA ought be be
leaning towards certified FF lenses (or at least the longer focal lengths) on the off chance that someday I'll have my Viridian.
