Originally posted by madison_wi_gal What else?
Not sure about brick wall tests. Brick walls don't contains very fine details and the test is sensitive to camera position due to depth of field.
If testing on a wall, I'd use news paper pages with lots of text to evaluate relative sharpness.
I'd suggest.
- auto-focus and manual focus at infinity distant line of trees at the horizon in the diagonal of the sensor, camera rotated at an angle, compare extreme corners and center
- focus at nearest distance, check that the lens can focus versus lens spec.
- center auto-focus accuracy at mid distance vs live view
- check each aperture settings in AV mode, from wide f3.5 open to max f22/f29, check that exposure is correct
