01-08-2009, 08:44 PM   #1
I've read the reviews... would like some more opinions on the DA 18-250
and if possible... sample pics at the 18 and 250 extremes?
Thanks.
01-08-2009, 11:03 PM   #2
jamesk8752's Avatar
I've put us a small gallery of test shots here: Pentax SMC-DA 18-250mm f3.5-6.3 Superzoom Lens Photo Gallery by Jim King at pbase.com
01-08-2009, 11:24 PM   #3
Class A's Avatar
QuoteOriginally posted by laissezfaire Quote
You'll fine heaps of samples at the Flickr group "The Tamron-based 18-250 zoom".
At 18mm you'll notice pretty heavy barrel distortion when the image contains straight lines. At 250mm the lens is softer than between 20-100mm but still very useful AFAIC.
01-09-2009, 12:06 AM   #4
Class A's Avatar
I shot this image of a bee at 250mm. It is a crop. Sharpened with Picasa. One may argue that "sharpening" is cheating, but remember that all sharpening does is to increase the contrast. If the resolution isn't there, sharpening won't help.
This 1600 ISO shot at 250mm by someone else looks mighty good.
01-09-2009, 01:22 AM   #5
It was a good lens while I had it. I never tested it but I was never convinced it was actually 250 at the long end... it always seemed a little short to me.
01-09-2009, 02:08 AM   #6
Class A's Avatar
Very nice pictures!
QuoteOriginally posted by kunik Quote
Like other internal focus lenses, the 18-250 changes the focal length with the focussing distance. The closer the object, the less the real focal length.
Too bad that it also changes focus while zooming. Prevents one from zooming in, focussing and zooming out again. Lenses behaving like this should be called "varifocal" rather than "zoom".
01-09-2009, 03:40 AM   #7
RaduA
Guest
Thanks.
Hi, Laissezfaire
Take this with a grain of salt but the rumour here is that this lens is/will be soon discontinued and a new Pentax design will take its place (DA18-200 say the same rumour).
Regards,
Radu
01-09-2009, 04:14 AM   #8
Class A's Avatar
QuoteOriginally posted by RaduA Quote
Are you suggesting he should wait to see what the 18-200 is like?
Hopefully it is not based on the Tamron 18-200 which isn't as good as the 18-250 but that seems unlikely.
Anyhow, one needs a lot of patience to wait for a lens that has only been rumoured about just yet. Doesn't that mean it will take ages until you actually can buy a copy?
I'd be surprised to see Tamron drop their 18-250, even if Pentax actually dropped their rebadged version of it. But perhaps I'm wrong.
01-09-2009, 04:24 AM   #9
I agree with Class A on that one. Especially since Tamron has recently released the updated design for this lens which is a 18-270 (currently Nikon and Canon Mount only).
01-09-2009, 04:46 AM   #10
RaduA
Guest
Even more so if Tamron won't drop their version (and I am sure they won't since the new 18-270 seems to be done with optical stabilisation in mind) it wouldn't hurt to wait 6-7 more weeks to see what is coming. I guess weather seals and SDM could make an interesting proposition and if the price is too big or range too limited or whatever at least the Tamron will be still there. And I think a lot of Pentax labeled copies will still be available for some time.
And no, there is absolutely no way Pentax will use a past Tamron (or Sigma or whatever) design for this (alleged) lens. This type of zoom is a very lucrative part of the range and I expect a very decent performer.
Like I said it's up to laissezfaire to decide but if I was him I would wait until PMA.
Radu
01-09-2009, 06:37 AM   #11
Here you go .....
Pentax DA 18-250mm f/3.5 - 6.3 Photo Gallery by alfisti at pbase.com
01-09-2009, 10:41 AM   #12
konraDarnok's Avatar
Prevents one from zooming in, focussing and zooming out again. Lenses behaving like this should be called "variofocal" rather than "zoom".
Eh? You own this lens? This is exactly what I do to get tack sharp pictures at wide angle focal lengths. Otherwise the focus can be pretty random at wide apertures. :ugh:
As to the poster, it's a nice lens and pretty universally liked amongst its owners -- and the best of the super zooms I've ever used.
01-09-2009, 11:41 AM   #13
BrianK's Avatar
For a general walk around/travel lens you can not beat it. I have used this lens more than any of my other lenses. Like most lenses of this type, the more light the better but it does a good job even in lower light conditions. (Alaska sunset shots) Hand held on ships rail and freehand.
Here are some random shots with this lens in all focal lengths and even indoors with flash. My site software removes the exif so if you need more info on a particular image just let me know and I can retrieve it from my Iphoto library.
Pentax DA 18-250
01-09-2009, 12:14 PM   #14
jsherman999's Avatar
Used to own the Tamron version, and it's a great outdoor lens. The only real problem I had with it is that it was just too slow on the long end - but for outdoor shooting in good light, it's unmatched in it's price range. The Tammy 70-300 is great also, but this thing goes to 18mm, for pete's sake.
01-09-2009, 12:18 PM   #15
PentaxPoke's Avatar
The Pentax 18-250 is my most used outdoor lens. I keep coming back to it, because it is so versatile. I did a comparison of my 18-250 and the DA* 50-135 on both the k20d and k10d and the only way you can see a difference is at 100% crop. Here are the pics:
k10d and k20d DA 18-250 and DA* 50-135 - a set on Flickr
MZ stands for the 18-250 and DAstar is the DA*
for those of you that don't want to go through the whole set, here is a 100% crop at 100mm for both the DA* 50-135 and the 18-250. Guess which is which:
(I always chuckle when I read some posters that claim that the Pentax 18-250 must be "soft" because it is a "megazoom." I guarantee that you cant tell the difference without going to extreme measures such as this.)
Here is one of the full images that the above was cropped from, so you can see how extreme the crop is:
k-mount, pentax lens, slr lens
Suggestion Read more at..... yusuf Site Suggestions and Help 7 10-08-2010 12:14 AM
Sigma 18-250 or Pentax/Tamron 18-250? mjbens01 Pentax SLR Lens Discussion 3 07-08-2010 09:10 PM
Pentax 18-250 always same as Tamron 18-250? kitkat Pentax SLR Lens Discussion 12 07-08-2010 08:30 AM
I've read the reviews - still need help -DA 50-200, FA 75-300, DA 55-300 Neisey Pentax SLR Lens Discussion 7 08-22-2009 08:43 AM
Why DA18-250 is double the price of Tamron 18-250? raider Pentax SLR Lens Discussion 6 12-13-2008 05:40 AM
All times are GMT -7. The time now is 04:00 PM. | See also: NikonForums.com, part of our network of photo forums!
