Originally posted by dan aron Sorry, about squeezing here but I need advices too.
I have a little bit different setup. Sigma 10-20mm and 35mm f2 to DA*16-50mm? Is it worth it? I know this one is really hard one and depends on preferred style. What's your choice?
I can't say what the other will say. But if I were you, I won't consider the DA* 16-50 f/2.8 as it is way too expensive to have and you have the risk in bad copy and it will be a bad idea to lose your Sigma 10-20mm. Your 35mm f/2.0, I assume FA is top notch for the 35mm with faster speed. If I were you, I will keep 10-20mm, keep 35mm f/2.0 unless you are ready to swap the FA 35mm to FA 31mm or DA 35mm f/2.8. The path to DA 35mm f/2.8 1:1 Macro is questionable as the two lens are different with one good for speed and the DA good for close up.
Again, if I were you and with a budget, I rather keep the two good lens and think of cheaper but good alternative to cover the range -- Sigma 17-70 OR Tamron 17-50mm f/2.8. The later is a better choice if you ask me. But Sigma 17-70mm f/2.8-4.0 should not be ignored as the extra 50mm to 70mm is very versatile and it makes the Sigma 17-70mm ideal as a wide-normal-portrait walk around. IMO, any 17-70mm range will beat 16-50mm for versatility. In terms of optical IQ, the Tamron 17-50mm is a better lens and of course, the best is the good copy of DA* 16-50.
Don't sell the good lens that you really love just to get to greener pasture with better lens people rave about. Sell only the loser or gear that has bored you after lengthly period of use.
Hin
