01-09-2009, 10:18 PM   #1
UpNorth's Avatar
Trouble with my FA 80 - 320 4.5/5.6.....
I've had my K20D for about a month now, and I can't seem to figure out this one issue I'm having. When I set it it to Tv mode in order to control the exposure, the following happens.....
- When using the "kit" lens (DA 18 - 55 3.5/5.6) I can set the shutter speed using th front e-dial just fine.
- When using the SMC FA 80 - 320 4.5/5.6 lens that I bought for my Zx-5n about 10 years ago I can't seem to set the shutter speed in Tv mode. In the viewfinder, the shutter speed just switches back and forth depending on the lighting, while the aperture just keeps reading "- -". The aperature ring is set to "A".
It's frustraring, as I'm trying to get some shots at my son's basketball games, and as you can imagine 9 out of every 10 shots don't freeze the action because i can't control the shutter speed. While it IS indoors, there seems to be ample light, and I've even tried "tricking" the camera by thinking - if it WAS a light issue - I'll point the camera directly at one of the lights because THEN I should be able to get enough light at f5.6 to be able to set the shutter speed, but no go. It does GIVE me a faster shutter speed, but it still doesn't allow me to set it with the front e-dial.
I wasn't sure if it was the lens or the camera for sure - until I tried my other Zx-5n lens - an FA 28 - 70 4/5.6. That one DOES allow me to set the shutter speed, so I'm assuming I have an issue with my FA 80 - 320 lens - as opposed to a camera issue.
I've tried rotating the aperture ring on it to be sure the pin works, and it moves just fine - so it's not stuck/sticking.
Any other ideas on what the problem may be?
Thanks in advance for any help.....
Tim
01-10-2009, 12:54 AM   #2
Class A's Avatar
QuoteOriginally posted by UpNorth Quote
Odd, I think it should work. I've used this lens on a K100D and could use Tv mode, as expected.
Perhaps one of the contacts on the lens mount needs cleaning? Sorry, this is not very helpful but at least you get a free bump.
01-10-2009, 05:10 PM   #3
UpNorth's Avatar
Thanks Class A.
As I have never cleaned the contacts on my lenses before, could someone please clue me in on the best method(s)?
Thanks,
Tim
01-10-2009, 05:18 PM   #4
Does everything work properly in AV mode when it is set on A? I have one that did not work on the A setting & I sent it off to be fixed last year.
01-11-2009, 01:04 AM   #5
ryan s's Avatar
It really does sound like an A setting fault on the lens...as in...it doesn't lock OR the A contact has come loose OR the A contact needs cleaning.
I cleaned off a contact on one of my PK-A Adaptalls but I honestly can't remember what with...
01-11-2009, 10:59 AM   #6
I tried cleaning on mine but it was not successful. Ended up sending to KEH for repairs. They had to replace and electronic part and it works great again.
aperture, camera, fa, front, issue, k-mount, lens, light, pentax lens, shots, shutter, slr lens, zx-5n
Faulty FA 80-320 EsBee Pentax SLR Lens Discussion 10 08-28-2009 06:49 PM
FA 80-320 repair foxx510 Pentax SLR Lens Discussion 0 03-14-2009 03:56 PM
Fa 80-320 Bife Pentax SLR Lens Discussion 7 01-08-2008 04:32 PM
Annoyed at my 80-320 Arpe Pentax SLR Lens Discussion 25 10-08-2007 09:32 AM
All times are GMT -7. The time now is 02:12 PM. | See also: NikonForums.com, part of our network of photo forums!
