Originally posted by excanonfd This is your original post in the thread to which I've replied to. You wrote "85/1.4 lenses", and "more trouble with 85s", which seemed to imply that you have handled more than one 85/1.4 lens.
Yes, I used a couple of 85/1.4s and a couple of 85/2. That part is correct.
My point was that I found it harder to focus these lenses at 1.4, 2, even 2.8. f/2 was actually the maximum aperture of some of these lenses, so focus shift couldn't be a factor in those instances.
Originally posted by excanonfd And then there is this; "even when stopped down", which I took to mean that you have handled an 85/1.4 lens whose maximum aperture can be reduced, ie: stopped down.
Yes, that is correct. Also, 85/2 lenses can be said to be stopped down even when used at maximum aperture, in comparison to an 85/1.4 lens.
Originally posted by excanonfd In the context of focusing, "even when stopped down" is meaningless since focusing is done with the lens at wide open for any A type lens with Pentax DSLR. You seem to be confusing stopping down to obtain the correct exposure with stopping the lens down to focus, two completely unrelated issues.
I was neither referring to exposure nor strictly to focusing. I was just talking about increased DOF obtained when you use a smaller aperture. As you should be aware, focusing errors have less impact when DOF is thicker. That is all I was talking about.
Originally posted by Rondec I thought that lenses didn't stop down to focus, unless you manually set the aperture ring to a different setting. If you are in 'A' mode focusing is done wide open and the camera only stops down during the shot. Maybe I am wrong though...
On second thought, he might be using the optical DOF preview control to focus with the lens stopped down and avoid the focus shift.
