Originally posted by zoeybird
I'm a little confused on what makes a good lens.
Lots of things. Large maximum aperture, high sharpness, high contrast, "good" color, "good" bokeh, lack of chromatic aberrations, lack of barrel or pincushion distortion, lack of vignetting (all terms you can look up for yourself if you are unfamiliar with them). Some of these are more subjective than others, and some of these factors are more important to some people while other factors are more important to other people (for instance, I don't care as much as some about bokeh, color, or vignetting, but am very sensitive to sharpness).
Quote: the type of lens itself equals more $$ (ie digital vs manual)
That doesn't really make sense. "Digital" isn't a type of lens. It just means someone decided the lens was appropriate for use on a digital camera. And the lenses marked "digital" aren't always more more expensive than lenses *not* marked "digital". The most expensive lenses available new for Pentax include that FA77 and FA31, neither of which is "digital". It is true that lenses marked "digital" are almost always autofocus and autoaperture, and these often are more expensive than corresponding manual focus, manual aperture lenses. But not always - again, there are some manual lenses that are unbelievably expensive too.
Quote: but what about clarity?
That's not really a well-defined photographic term. You are probably referring to some combination of sharpness (more or less the same thing as resolution) and contrast. And the only way to know is to read reviews.
