01-11-2009, 05:07 PM   #1
Will this lens do "macro" for me?
Sorry about my ignorance, but I recently purchased this lens used off the marketplace here on pentaxforums. I am very happy with the lens, however, I guess I don't know if it will give me close up pictures. Oh, I'm using it on a K100D.
I purchased it for banging around with me for soccer games, softball games, etc., and not for close up work.
Any info you could provide on this? Thank you.
vmax84
01-11-2009, 05:22 PM   #2
It does say "macro" on it, but if it does give close-up images, for the life of me, I can't figure it out.
vmax84
01-11-2009, 05:28 PM   #3
This is a close focussing zoom lens but not a true macro. You can get to 1:39 with this lens but you want to get to 1:2 or 1:1 for real macro. For that you would need a macro lens. There are lots of them out there at a range of prices.
Do you have a budget?
01-11-2009, 05:31 PM   #4
QuoteOriginally posted by joelovotti Quote
Well, with the economy the way it is, I really need to stay under a couple hundred bucks.
vmax84
Or, keep saving and just have fun with the stuff I got, too!!
01-11-2009, 05:47 PM   #5
It looks like that lens is a good starting point for macro work. As is it'll do a 1:3.9 magnification at full zoom. That's a field width of about 3.9*22mm=86mm.
You can add a good achromatic diopter lens on the front to get higher magnifications. The formula is:
New_mag=Old_mag+Focal_Length*Diopter(1+old_mag)
for your case, that's:
New_mag=old_mag + 0.3*diopter(1+1/3.9)=0.26+0.377*diopter
So a relatively weak close-up diopter lens like a nikon 6T* = +2.9 diopter will give you a magnification of up to about 1.35:1 for a field width of 22mm/1.35=16.3mm
That sounds like a good setup to me. Magnifications higher than 1.35 or so will be hard to handle.
Your lens has a real advantage of having its maximum magnification at its longest focal length. That gives you good working distance which, beside making lighting easy, keeps you away from stinging insects.
Dave
*A 6T currently on eBay has a bid of about $9usd now. It'll maybe go for $25-35?
01-11-2009, 06:41 PM   #6
An alternative to a true macro lens, use an extension tubes with a normal 50 mm lens. There are quite a lot available in ebay at low cost or in the market pl. Another option, use a reverse ring adapter for a normal 50 mm lens- low cost on adapter. You have the feature of 1:1 mag but depth of field is shallow and shorter focusing distance.
Theere are some articles written here on this subject already.
marcus
01-11-2009, 10:00 PM   #7
Marc Sabatella's Avatar
QuoteOriginally posted by vmax84 Quote
Set it to the longest zoom setting (300mm), set the focus as close as it goes (1.5m, according to the box), and you'll get magnification of 1:3.9 - which is to say, not as quite good as the kit lens (18-55) set to its longest zoom setting and shortest focal distance.
Stick a Raynox 150 in front of it and it will focus a *lot* closer snd thus take much more closeup pictures. But it will probably vignette.
games, k-mount, lens, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
"macro" feature of Tamron 18-200 lens WMBP Pentax DSLR Discussion 19 01-08-2007 04:04 PM
All times are GMT -7. The time now is 05:53 PM. | See also: NikonForums.com, part of our network of photo forums!
