Originally posted by Nowhere Matt Yes but mine, apparently is an older 60AZ- S model. The eye piece holder has an inner diameter of 2.5 cm; just under one inch.
I bought and returned the Bushnell and Celestron adaptor hoping I could thread one of them on somehow inspite of them not fitting as they should down in the eye piece holder. I thought one might even thread onto the focusing tube but alas...
I think someone on this thread brought up an issue of focusing if adaptations are not correct so I may just look for a nice $10-$20 scope at garage sales this year.
Well, all hope is still not out! You can get 0.96" to 1.25" adapters:
TELESCOPE CAMERA ADAPTERS |TelescopeAdapters.com -
Telescope Hybrid Adapters & Extensions
Based upon such you can then expand with 1.25" and T2 photographic couplers.
Better still - but I don't know the details of yor scope:
If you could connect a T2-ring directly to the draw tube you would be better suited for prime focus photography. On my vintage Vixen Polaris R-100L (also a .96" system) this works as follows: Inner 36.4 mm thread on draw-tube --> outer 36.4mm thread to outer T2 thread adapter --> T2-ring. That way you will get very little vignetting on film and none with an APS-C sensor in prime focus.
Anyway, here is a picture of the 0.96"-to-1.25" type adapters that are still available:
